×We are planning an upgrade service pack level to SQL 2008 SP3. We need to make sure there is no compatibility issue or anything like that.
Thank You... for the quick response
Has anybody done this upgrade, if so was there any issues?
Hi Thomas
I believe that you'll have no issues after upgrading the SQL server. However, just to play safe, I'd suggest to create a trial environment to test it.
Therefore, download a new JIRA > Install it as a evaluation license > Install a SQL server (express edition) with SP3 and import your valid JIRA XML backup. It should works.
Anyway, you always have https://support.atlassian.com for emergency. Just don't forget to keep a valid database and JIRA XML backup in a safe place.
Paulo Renato
