Quick filter for "not commented over 3 days"
Valentina Grishkevich
July 9, 2019
Is there a way to create a quick filter that shows only issues which haven't been commented over last 3-4-5-whatever days?
I know we have "updatedDate" thing but it's not working the way I need. Any activity on the ticket (like logging time) will update this parameter while I want to track comments only.
2 accepted
Olga Videc
Hello @Valentina Grishkevich
You will need ScriptRunner plugin for this, because of this specific JQL function.
I need the same thing, couldn't do it without a plugin.
Enter this into your advanced JQL search
issueFunction in lastComment("before -3d")
BR, Olga
Deepti Hasija
March 3, 2024
How can we make a filter for comments not added in last 3 business days?
Manuel Bastardo Castellano
July 9, 2019
Hi Valentina, you also should try this recomendation from @Kristian Walker (Adaptavist)
This requirement can be used using the Script Fields functionality provided by the ScriptRunner Plugin.
The way to do this is to set a new Script Field called Last Comment Added and configure its searcher type to be Date Time Range Picker and ensure this field is set to appear on issues for all projects and issue types.
You should then add the script below to the Script Field
def comments = ComponentAccessor.getCommentManager()?.getComments(issue)
// If the current Issue has comments then get the date that the last comment was created
if (comments) {
    return comments.last()?.created as Date
Finally you should then ensure that the Template for the field is set to Date Time Picker like in the screenshot below and then you will see details of when the latest comment was added such as in the screenshot below.
I hope this helps
Kristian
