I have an issue/ticket with more than 20 worklogs (around 42 worklogs including the oldest one).
Now, I sent a request to retrieve those worklogs using GET method and this URL https://xxyyzz.atlassian.net/rest/api/2/issue/<issue>/worklog
All worklogs were retrieved but some description seem incorrect. Those description were all "time-tracking". It seems that JIRA has hidden or changed the correct value.
Question is how will I be able to retrieve the correct comments?
Is this an issue with JIRA REST API?
Could you please post a screenshot?
Here's what a typical worklog looks like (sensitive information removed), and you should probably look for the 'comment'.
"self": "",
"author": {
"self": "",
"name": "",
"key": "",
"emailAddress": "",
"avatarUrls": {
"48x48": "",
"24x24": "",
"16x16": "",
"32x32": ""
"displayName": "",
"active": true,
"timeZone": ""
"updateAuthor": {
"self": "",
"name": "",
"key": "",
"emailAddress": "",
"avatarUrls": {
"48x48": "",
"24x24": "",
"16x16": "",
"32x32": ""
"displayName": "",
"active": true,
"timeZone": ""
"comment": "this is the worklog description you should be looking for",
"created": "",
"updated": "",
"started": "",
"timeSpent": "",
"timeSpentSeconds": 0,
"id": "",
"issueId": ""
Hope this helps.
Shaakunthala
"self": "",
"author": {
"self": "",
"name": "",
"key": "",
"accountId": "",
"emailAddress": "",
"avatarUrls": {
"48x48": "",
"24x24": "",
"16x16": "",
"32x32": ""
"displayName": "",
"active": true,
"timeZone": ""
"updateAuthor": {
"self": "",
"name": "",
"key": "",
"accountId": "",
"emailAddress": "",
"avatarUrls": {
"48x48": "",
"24x24": "",
"16x16": "",
"32x32": ""
"displayName": "",
"active": true,
"timeZone": ""
"comment": "This is the 20th worklog of this issue",
"created": ",
"updated": ",
"started": "",
"timeSpent": "",
"timeSpentSeconds": ,
"id": "",
"issueId": ""
--- OMITTED SOME WORKLOGS HERE ---
"self": "",
"author": {
"self": "https://xxyyzz.atlassian.net/rest/api/2/user?username=addon_is.origo.jira.tempo-plugin",
"name": "addon_is.origo.jira.tempo-plugin",
"key": "addon_is.origo.jira.tempo-plugin",
"accountId": "",
"emailAddress": "is.origo.jira.tempo-plugin@connect.atlassian.com",
"avatarUrls": {
"48x48": "",
"24x24": "",
"16x16": "",
"32x32": ""
"displayName": "Timesheets",
"active": true,
"timeZone": ""
"updateAuthor": {
"accountId": "",
"avatarUrls": {
"48x48": "",
"24x24": "",
"16x16": "",
"32x32": ""
"active": true,
"timeZone": ""
"comment": "time-tracking", // "This is the 42nd worklog of this issue" <-- this should be the comment
"created": "",
"updated": "",
"started": "",
"timeSpent": "",
"id": "",
"issueId": ""
Hi @Shaakunthala,
Please take a look at the example above.
In this example, the comments should be in this format:
This is the (worklog order) worklog of this issue
The 1st worklog (not shown above) and up to the 20th worklog, they displayed the correct comment.
However, starting from the 21st worklog (not shown above) and up to the 42nd worklog, they all showed 'time-tracking' as the comment which is not the right one.
Note: I didn't removed some information as it might be a factor to this issue.
Gotcha! "is.origo.jira.tempo-plugin"
This is new to me. Looks like you are using Tempo for time tracking. Do you see the correct comment in the JIRA user interface? In that case probably Tempo is storing worklog comment in the plugin data store. To drill down, we need to find the "AO_.*" table in the database that corresponds to Tempo.
However, that doesn't solve your problem. Try installing JIRA Rest API Browser add-on and uncheck "Show only Public APIs". This might help you to find a REST API endpoint (if provided by Tempo) which is capable of retrieving the correct description/ comment.
Shaakunthala
As suspected, tempo is involved in this issue.
Is this a chrome extension/plugin? Please guide me how to do this.
Don't get misled by the 'browser' part in the add-on's name. ;)
It's a JIRA add-on: https://marketplace.atlassian.com/plugins/com.atlassian.labs.rest-api-browser/server/overview
Just noticed that you're using JIRA Cloud. This add-on isn't available for Cloud. So my recommendation is to set up your own trial JIRA instance with Tempo and do some research. (just to find a REST endpoint if available)
Once REST API Browser add-on is installed, go to http://test-instance-url/plugins/servlet/restbrowser#/ to access the API browser.
Shaakunthala
Thanks for the help @Shaakunthala
Anyways, I found something and it's a bit hassle way to retrieve the worklog's correct comment. I'll just leave it here in case someone encounters the same issue.
1) Send GET request with URL https://xxyyzz.atlassian.net/rest/api/2/issue/<issue key>/worklog/<worklog key>/properties/tempo
2) Retrieve tempo_id
3) Send another GET request with URL https://xxyyzz.atlassian.net/rest/tempo-timesheets/3/worklogs/<tempo_id>
4) Finally, retrieve the correct comment
P.S. Hopefully, JIRA team can create an endpoint to support this issue.
Appreciate posting your findings here. Definetely it's going to help someone. :)
