REST Client get all issues of project
Mokuyobi
Hey there,
I want to get all issue keys of a project via Rest. Is there any method for that?
In the api I do not find any method there for.
5 votes
C_ Faysal
January 1, 2013
hi.
you can trigger all issus of a project just like a jql query...
find more details here
http://docs.atlassian.com/jira/REST/latest/
C_ Faysal
January 1, 2013
f.e.
/rest/api/2/search?jql=project="Your Project Key"
https://developer.atlassian.com/display/JIRADEV/JIRA+REST+API+Example+-+Query+issues
Like Miguel Esteban likes this
Pallavi Shastry
May 11, 2014
Hi C. Faysal,
This gives you just first 50 issues, how can i get all the issues? I have around 1348
Like 4 people like this
Marc Menges August 25, 2014
Same problem here. Do I have to make two calls in order to get all issues?
CEDRIC ZABEL
August 26, 2014
If you check the docs, you’ll see information about the “maxResults” parameter to the “/rest/api/2/search” resource. That’s what you want.
Like 3 people like this
Marc Menges August 26, 2014
This is everything I could find regarding "maxResults": "the maximum number of issues to return (defaults to 50). The maximum allowable value is dictated by the JIRA property 'jira.search.views.default.max'. If you specify a value that is higher than this number, your search results will be truncated."
The problem is, that you may not know how many there are before doing the query. And setting the value to some randomly high number feels wrong. I really don't know why it has to be that complicated. Why is the default 50 and not 'all'?
For everyone who has the same issue: Just use -1 as value for maxResults. That 'somehow' works.
CEDRIC ZABEL
August 27, 2014
Yeah, that’s how “maxResults” works. You don’t put in how many results you think you’ll get. You put in how many results you can possibly handle. It’s like a paged display of results. If you go to Google and search for “baseball,” Google won’t send over all 500,000,000 results that it knows about.
Obviously, whatever Jira instance you’re dealing with is a lot smaller than Google, so maybe whatever is gathering the results of your REST call can deal with all the results Jira can throw at you. In this case, setting “maxResults” to an arbitrarily high number, or the special value of -1 is the correct thing to do. That’s how it works.
Marc Menges August 27, 2014
Got it. Thanks.
Mei Ying Phuah August 25, 2017
Hi. anyone successful to get the issues no exceed 50 by using vba? can share the coding here?
sayeed1310
maxResult attribute helps only until 1000 issues.
Is there anything that can help get beyond this limit?
tarunmunjal
December 15, 2020 edited
function jira_pagination () {
maxResults=50
total_items=
$1
if [ 0 -lt $(expr $total_items % $maxResults) ]; then
total_iterations=$(expr $total_items / $maxResults)
else
total_iterations=
fi
count=0
start_at=0
results=
while [ $count -le $total_iterations ]
do
r
esults+=$(${@:2}&startAt=$start_at)
start_at=
$(( $start_at + $maxResults ))
count=
$(( $count + 1 ))
done
echo "${results}"
function jira_get_all_issues_in_project() {
project_key=
"${1}"
number_of_total_boards=
$(curl -s -u ''$JIRA_USERNAME:$JIRA_PASSWORD'' -X GET -H "Content-Type: application/json" https://jira.com/rest/api/2/search?jql=project="${project_key}" | jq .total)
issue_results=$(jira_pagination $number_of_total_boards curl -s -u ''$JIRA_USERNAME:$JIRA_PASSWORD'' -X GET -H "Content-Type: application/json" https://jira.com/rest/api/2/search?jql=project="${project_key}")
echo "${issue_results}"
jira_get_all_issues_in_project "someproject"
If anyone is still looking for a solution. You can use the following bash functions to get a list of all the issues. It will iterate over all the pages and in the end give you all the issues in a project. It will be slow depending upon how many issues are there. Change the jira server and pass the project.
52 votes
sayeed1310
So there are two things one has to do..
  1.  Get the total issues in a project with a basic and 'quick and light' query
    1. I say light and quick because we are simply establishing the total count of issues in the project in this step.
    2. URL: https://<server>/rest/api/2/search?jql=project=<YourProjectKey>&maxResults=0
    3. This gives a result like -->
      { "startAt": 0,
        "maxResults": 0,
        "total": 22114,
        "issues": [] }
  2. Iterate over the total number of issues to fetch the desired details/fields of each issue.
    1. Note: Maximum allowable fetch seems to be 1000 issues at a time. So let's break it up for iteration using the parameters startAt and maxResults.
    2. startAt is the index of the issue in the 'complete list (22114 items as above)'
    3. We can also filter the fields that we are interested to fetch. This is especially useful because failing to provide this will result in fetching all fields in each issue, including custom fields. Down below, I'm interested only in key, summary and description fields.
    4. for startIndex in range(0, 22114, 1000):
      search on URL: "https://<server>/rest/api/2/search?jql=project=<YourProjectKey>&fields=key,summary,description&maxResults=1000&startAt={startIndex}"
Robert Walters
August 28, 2018
This should be the top answer IMO. Thanks a lot!
Like 8 people like this
Dakota Palmer
December 8, 2019
The real MVP
Like 2 people like this
Jowin Cueto
January 16, 2020 edited
When i use this,
 I got  100 issues, unlike before I only have 50, but I want more than hundreds of issues
sayeed1310
@Jowin Cueto , what is your start index? Did you try running your query inside Jira environment to verify how many issues it returns? We would simply need to provide the same query to the "jql" parameter.
3 votes
This is everything I could find regarding "maxResults": the maximum number of issues to return (defaults to 50). The maximum allowable value is dictated by the JIRA property 'jira.search.views.default.max'. If you specify a value that is higher than this number, your search results will be truncated.
Nagarjuna Chilaka
December 2, 2020
Specify maxResults=None, This worked for me.
I was able to get all the results from jira.
jeoppy jeoppy
October 22, 2018 edited
just sharing my resolution to the concatenation of results , and getting all the info
i have a jira query function in perl
, which is called for every jql i need and return a ref to all the issues that come back
so i am calling the function as follow :
defining the max results jira allows to retrieve:
use constant {
JIRA_MAX_RESULTS => 1000,
initialize my jql :
my $jira_Jql = 'project = "GIGI" and type in ("Bug" , "Minor Bug") ';
define which return columns I need (instead of getting big hash back this will narrow it a bit ) :
my $returnedColumns = [ qw/key/ ];
or another example to get key + status :
my $returnedColumns = [ qw/key status/ ];
and I call the function :
my $jiraResultsRef = queryJira($jira_Jql, $returnedColumns);
:the function itself looks as below and iterate via the results
first it run the jql with maxresults = 0 to get the number of results which exist,
then based on that it initializes the amount of iterations need to do in order to get all the info .
last stage is to concatenate the results and returning the ref to this array .
use JIRA::REST;
sub queryJira { my ($jira_Jql, $returnedColumns) = @_;
# set Connection to the jira API.
$_jiraUrl = "http://$_jira_host:$_jira_port";
$_jiraConnection = JIRA::REST->new({
url => $_jiraUrl,
username => $_jira_user,
password => $_jira_pass,
# return search total number of results
my $queryTotalOfResults = $_jiraConnection->POST('/search', undef,
jql => $jira_Jql,
startAt => 0,
maxResults => 0,
fields => $returnedColumns,
#check the amount of issues returned :
my $totalResultsNumber = $queryTotalOfResults->{total};
# dividing the number with the jira's MAX results which are allowed via "ceil" which will give the number of iteration needed
my $numberOfIterations = ceil ($totalResultsNumber / JIRA_MAX_RESULTS) ;
print ("\n \$totalResultsNumber: $totalResultsNumber \n \$numberOfIterations : $numberOfIterations \n\n");
my $queryResults;
my @_returnedResults ;
if (not $totalResultsNumber) #if no results found
return;
#assuming there are result start looping :
for(my $counter=0; $counter <= $numberOfIterations; $counter++)
$queryResults = $_jiraConnection->POST('/search', undef,
jql => $jira_Jql,
startAt => ($counter*JIRA_MAX_RESULTS),
maxResults => JIRA_MAX_RESULTS,
#and concatenate them to one big happy @_returnedResults
@_returnedResults = ( @_returnedResults, @{$queryResults->{issues}} );
# making sure i got the same amount of keys returned :
print ("\n total of keys in the hash :" . (scalar @_returnedResults) . "\n" );
return \@_returnedResults;
Lucian June 22, 2018 edited
I have the same issue with worklogs, I can not get more than the first 20,
I tried all the parameters specified in the Jira pagination spec, ex:
/issue/GPIM-7136?fields=worklog&startAt=15
/issue/GPIM-7136?fields=worklog&maxResults=10
/issue/GPIM-7136?maxResults=10
I am always getting back
"fields": {
"worklog": {
"startAt": 0,
"maxResults": 20,
"total": 43,
John Nguyen
Hi All,
  What doe the APIs look like if I want:
1 - Get all the sprint IDs of a project?
2 - Get all the issues in a specific sprint?
I'm new to the API syntax and looks like the API docs did not explain the syntax well.  I'm continue to loop at the API doc and its API examples while waiting for some good tips.
Thanks a lot guys
J.N
John Nguyen
I found the example page where it describes how to do all these.
Thanks anyway folks
J.N
Customer Test Account
April 5, 2018
Would you like to share this example page maybe @John Nguyen ?
Nacho Pérez Alonso
June 7, 2016
some requests as:
/rest/api/2/search?jql=project="Your Project Key"&startAt="start"&maxResults="max"
where max limit is 1000. If you try a number greather than 1000 rest api returns only 1000 results.
You must to look "total" param in response to know how many request have to do.
FYI look at pagination section: https://docs.atlassian.com/jira/REST/latest/
Regards
mark mark October 18, 2017
I tried with "/rest/api/2/search?jql=project" and works.
However for entire string like /rest/api/2/search?jql=project="Your Project Key"&startAt="start"&maxResults="max" , 404 not found error is returned.
I am using JIRA 6.2. Is it not supported?
Ketan Vidhate
October 31, 2017
Please provide space before and after '&'
rest/api/2/search?jql=project="Your Project Key" & startAt="start" & maxResults="max"
Like Mark likes this
Register today
