Re-indexing Issue
Mohin Uddin
Hi expert,
Is it necessary to perform system re-indexing once we make changes to custom fields or anything else in every time.?
Mohin
Nic Brough -Adaptavist-
May 1, 2014
It really depends on the nature of the change you've made, but it's quite a complex set of things that you can do that *might* require a re-index. The system message you get when you change fields is over-cautious and asks you to re-index when you don't need to quite often, but it's quite hard to know when it's actually right.
Some simple rules - if you change the searcher on a field, or reduce the field's context, and the field already has some data in it, then yes, you absolutely need to reindex. The rest of the cases are more fuzzy
The advice it gives about making lots of changes and then doing a re-index when you've finished is good
