Reading h2db.mv.db fail after switching IP
ABC Support
November 21, 2019
Morning Everyone,
When I shutdown VM and use another IP to carry VM, JIRA software cannot read h2db already, do you have any advise? Do you have method I can retrieve my project works?
Thanks everyone
80355328 is h2db.mv.db file size
Error Log:
Caused by: java.lang.IllegalStateException: Reading from cache:nio:C:/Program Files/Atlassian/Application Data/JIRA/database/h2db.mv.db failed; file length 80355328 read length 768 at 84646650 [1.4.185/1]
at org.h2.mvstore.DataUtils.newIllegalStateException(DataUtils.java:773)
at org.h2.mvstore.DataUtils.readFully(DataUtils.java:443)
at org.h2.mvstore.FileStore.readFully(FileStore.java:98)
at org.h2.mvstore.Page.read(Page.java:189)
at org.h2.mvstore.MVStore.readPage(MVStore.java:1830)
at org.h2.mvstore.Page.getChildPage(Page.java:216)
at org.h2.mvstore.Cursor.fetchNext(Cursor.java:150)
at org.h2.mvstore.Cursor.next(Cursor.java:50)
at org.h2.mvstore.MVStore.readFileHeader(MVStore.java:696)
at org.h2.mvstore.MVStore.<init>(MVStore.java:357)
at org.h2.mvstore.MVStore$Builder.open(MVStore.java:2769)
at org.h2.mvstore.db.MVTableEngine$Store.<init>(MVTableEngine.java:162)
at org.h2.mvstore.db.MVTableEngine.init(MVTableEngine.java:98)
Nic Brough -Adaptavist-
December 7, 2019
I'm afraid your h2 database has failed.  This happens a lot, and it's the reason Atlassian tell you not to use it for anything that really matters (dev and test systems can be recreated, no huge loss if they fail)
The best you can do is check the "exports" directory for a recent backup, fire up a new installation and import the backup into it.
Whether that works or not, you need your next Jira install to use one of the four supported databases.
Learn more
