Recognize internal comment in Automation for JIRA
Deleted user May 15, 2018
I am trying to see if the comment added (it is also a trigger) is a public or internal one. I have found the smart values like
{{issue.comments.last.body}}
{{comment.internal}}
 but I am not sure where should they be compared, and I am pretty sure the true or false would not equal the result of last or last.body.
Does anyone know the best smart values or other way to do this?
2 accepted
4 votes
{{comment.properties."sd.public.comment".internal}}
equals
false (or true)
is how I managed to resolve it
Junio Fernandes
How is this supposed to work? What "sd.public.comment" means? I've tried this but doesn't work. Tks.
Stephen Letch
Thanks @[deleted]
Keven Perreault February 4, 2020
Thanks @[deleted] worked like a charm !
Jim Copeland February 23, 2022
Where can we find these regex property values? Hoping to find more like this for other tasks.
Asbjørn Søborg-Madsen March 20, 2022
If you are looking for what regEx you can utilize you can check out Pattern (Java Platform SE 7 ) (oracle.com)
If you want to know what fields Jira exposes you can start here What are smart values? | Cloud automation Cloud | Atlassian Support
I find it easier to just test against an actual issue with the JSON exposed at:
https://YOURNAME.atlassian.net/rest/api/2/issue/ISSUEKEY?expand=names
replace the values in bold with your own.
Noah Hofmann
This is gold! Thank you!
Filipi Lima
March 20, 2023
A quick note - on Server/DC 9.4.1 I just tested it with:
I had a simple rule with "when comment created" and I use advanced compare condition to match that to true or false and it worked correctly.
eilon_elphi October 30, 2023
This was great - exactly what i needed. on my end, needed the "does not equal", but most importantly needed to know the path {{comment.internal}}. thx @Filipi Lima !
worked as expected.
