Recover from failed import
Dan Fabulich November 2, 2012
I was running the Bugzilla importer and it lost connectivity with MySQL. My fault.
The problem is that now my JIRA is full of half-imported junk. The log says:
Unexpected failure occurred. Importer will stop immediately. Data maybe in an unstable state
What do I do now? How do I clean up this failed import so I can try again?
Norman Abramovitz
November 2, 2012
If you cannot just start over (ie uninstall and delete the database), I would try using the database integrity checker. I would then see what issues got loaded and remove those from the CSV file. Then start loading again.
https://confluence.atlassian.com/display/JIRA051/Using+the+Database+Integrity+Checker
