Recursive global transition
Stephan Hostie April 16, 2014
I created a global transition in a workflow, to allow reject from all states. A strange behaviour is that the reject transition is also present in the rejected state. Users pressed the reject button several times, thinking it didn t work.
Is there a way to prevent this?
Boris Georgiev [Appfire]
April 16, 2014
I think you've got a couple of options (not sure if these are all possible options but at least the ones I can think of)
  1. Add condition which allows this transition only if Status != Rejected
  2. Change the global transition to common transition and remove the rejected->rejected
