We have a Load Balancer for JIRA (as of now we are having only one instance but we wanted this for future use)
IDEAL SCENARIO and LB is working fine as mentioned below
http:jira.example.com ---- > href="https://jira.example.com">http://server1:8080
https://jira.example.com ---> https://server1:7443
But once we implemented redirecting from port 8080 to 7443 , this port is getting appended on DNS name as well......that is when someone types http:jira.example.com it is taking to https:jira.example.com:7443(which doesn't exist)
My intention is it should be redirected to https:jira.example.com instead of https:jira.example.com:7443
IS there any settings/configuration where can fix this issue ?
Modified server.xml
<Service name="Catalina">
<Connector acceptCount="100" connectionTimeout="20000" disableUploadTimeout="true" enableLookups="false" maxHttpHeaderSize="8192" maxThreads="150" minSpareThreads="25" port="8080" protocol="HTTP/1.1" redirectPort="443" useBodyEncodingForURI="true"/>
All calls will be diverted from LB server will be pointed to port 443, http:jira.example.com gets diverted to https:jira.example.com , if you want to access using your server name then it would be https://server1:7443 and only drwaback is http://server1:8080 will not work as it gets redirected to https://server1:443</span<>>
