Redmine to JIra Migration
Krishna M S March 12, 2019
We have a Redmine 3.x hosted internally and plan to migrate to Jira.
I suppose Jira has a Migration tool.  Do we need to expose our existing server for the Migration?
Daniel Eads
March 12, 2019
Hey Krishna,
The recommended method for importing data from Redmine to Jira Cloud is with a CSV file you generate from Redmine. Since you'd download this CSV file to your local machine and then upload it to Jira Cloud, there is no need to expose your Redmine server.
We do offer a Redmine Importer plugin for Jira Server that you can use if the CSV is not working for some reason. This would be a longer process than importing a CSV to Jira Cloud, so I don't recommend going this route unless you have trouble with the CSV. The steps for using the importer would be:
  1. Install a Jira Server instance (this can be on your local machine) using a trial license
  2. Follow the steps on our Importing from Redmine document to have Jira Server connect to Redmine and import the data
  3. Create an XML export of Jira Server as described on our Server to Cloud migration documents
  4. Import the XML file into your Jira Cloud instance
Daniel
Krishna M S March 14, 2019
I checked online for Steps on how to generate CSV from Redmine. Is there any documentation regarding the same?
Krishna M S
Daniel Eads
March 14, 2019
Hey Krishna,
While on the Issues page for a project, you should see a CSV option down at the bottom:
image.png Note that if you're looking at hundreds of projects, it may be faster to go with the Jira Server / Redmine Importer option I described. But if it's just a handful, it should be reasonable to export the projects from Redmine and upload to Jira Cloud individually.
Register now
