Redmine to Jira Migration
Krishna M S March 11, 2019
We are using Redmine version 2.4.3 hosted in house. We plan to migrate to Jira Cloud. Is it possible to migrate all Redmine tasks and Projects to Jira?
Krishna M S
Tarun Sapra
Hello @Krishna M S
From the docs
https://confluence.atlassian.com/adminjiracloud/migrating-from-other-issue-trackers-884344525.html
Redmine
We recommend exporting your Redmine data to CSV to import it to Jira.
Tarun Sapra
If you want to migrate more data which mightnot be supported by CSV. Then setup a evaluation Jira server version and import your data from Redmine  to Jira server and then take the backup of the Jira server and then restore on cloud. It's more work but it should give you more flexibility in terms of data.
Tarun Sapra
As on Jira server, migration from Redmine is better supported I feel
https://confluence.atlassian.com/adminjiraserver/importing-data-from-redmine-938847599.html
Like • Kirankumar Talapaneni likes this
Dima Lazarchuk
Hey Krishna,
Are you able to export your data to CSV?
HI,
We do not have Jira yet. I am not sure if the CSV import can migrate everything in Redmine
My Management wanted to know the feasibility before taking a decision? Are there any third party or commercial tools available?
Krishna M S
Mihail Atanasov
December 16, 2019
Hey Krishna,
Have you already moved over to Jira yet?
Mihail
Register now
