Two different users can link the same issue in the ticket, cause redundant linking.
I was wondering is this a bug in JIRA ?
Thanks in advance for your answer! image2016-6-10 14:4:13.png
Johan,
Most probably the links are not duplicated but the Related link type has the same name for both inward and outward links, so what happened is that you have a link from IMA-619 to your issue and a link from your issue to IMA-619.
JIRA groups all the links based on the link type (and direction) name, so since Related issue link type has the same name/label for both inward and outward links - relates to all the links are grouped in the same section which makes it look like you've got duplicate links.
So the answer is - it's not a bug
Hey guys,
I hope you are doing well! Thank you so much, that you are trying to help me! I didn't expect to receive an answer from someone that I know. Great surprise, @Boris Georgiev [Botron] special thanks!
My case has been closed!
@Johan Lambov
Would you please click "Accept" on the answer, so the question is closed. Thanks
Hi Jonan and welcome to Answers!
What version of JIRA are you using?
Can you provide a screenshot of the link action dialog when you type IMA-619 in the Issue field, what does the autocomplete return?
Hi Johan
What's the version of JIRA you're using ?
Did you create these links from the UI or using some kind of script/add-on ?
