Hi Team,
Actually at present my client is using Power Utilities for Jira Plugin. Now they want to drop that and move to either JSU or JMWE. The issue is that in Power Utilities for Jira supports: 1.JQL validator 2.Assign from field post function and 3.Regex Validator
Do these functions are also supported by either one of the plugin JSU or JMWE. I have worked around on this but I didnot find the exact solution. So please me out in this.
Thanks alot!!!!!
Regards, Nikhila
Hi @Nikhila Pikkili ,
you can indeed do all this with JMWE:
issue.getAsString("a field") ==~ /a regex/
Ηι @Nikhila Pikkili
As far as I know about JMWE it does have a JQL validator, when you use this with the built-in script Post function.
What exactly you mean with (2)? I mean you can have a CF, and with JMWE you can copy the value from that CF to the assignee, and the issue will be assigned.
Concerning the regex validator, I'm not sure that it has this per se, BUT it does provide a result box, in which you can see if it will return an error, or the value of your code.
I'll mention @David Fischer who will be able to give you a more proper answer about this.
Alex
