I'm using a scripted field (scriptrunner) for calculating a response time.
I use s scriptrunner service for reindexing issues with high priority.
Most of the time the value for the scripted fied is fine and search works.
But sometimes the values are wrong => calculated field hold wrong values on search.
I can't find the reason why most of times it works and sometimes not.
Below the code of my reindex service (runs every 30 min)
Thanks for any hint
Dieter
jqlSearch = 'project = IM and status = Offen and priority = "Major incident"'; userManager = (UserManager) ComponentAccessor.getUserManager(); ApplicationUser appUser = userManager.getUserByKey("admin"); User user = appUser.getDirectoryUser(); ComponentAccessor.getJiraAuthenticationContext().setLoggedInUser(ApplicationUsers.from(Assertions.notNull("user", user))); SearchService searchService = ComponentAccessor.getComponent(SearchService.class); IssueManager issueManager = ComponentAccessor.getIssueManager(); IssueIndexManager indexManager = ComponentManager.getInstance().getIndexManager(); List<Issue> issues = null; SearchService.ParseResult parseResult = searchService.parseQuery(user, jqlSearch); if (parseResult.isValid()) { def searchResult = searchService.search(user, parseResult.getQuery(), PagerFilter.getUnlimitedFilter()); issues = searchResult.issues; issues.each() { Issue issue -> boolean wasIndexing = ImportUtils.isIndexIssues(); ImportUtils.setIndexIssues(true) MutableIssue myIssue = issueManager.getIssueObject(issue.id); indexManager.reIndex(myIssue); ImportUtils.setIndexIssues(wasIndexing); } } else { log.error("[Index Service] Invalid JQL: " + jqlSearch); // Log errors if invalid JQL is used so we can fix it }
Hi Dieter,
Did you try to disable cache in your scripted field script ? Many inconsistencies are because of caching.
No I did not.
So I just have to include
enableCache = {-> false}
at the beginning of the script?
yes that's right, and when you make sure that this solves your inconsistency problem, then (if the reIndexing was to address that issue only) you can discard the reIndexing service.
