Release Date not populating
Jagriti
Hi
I have created a JQL to pull through a list of all items in a release , for next three releases
"project = "IT-Ops Team" AND fixVersion in ("1st Infra Slot - May | 11/5/19", "1st Infra Slot - June | 15/6/19", "1st Infra Slot - July |13/7/19") AND issuetype in (Epic, Task, Story)"
The data which gets pulled is correct , however , the "Release Date" column in always blank, the fix version is not pulling the release date .All fix versions have been created with release date .
How can I solve this issue to display appropriate "release date" for each fix version, please assist .
Tarun Sapra
May 6, 2019 edited
Hello @Jagriti
Currently it's not possible to display release date in the issue navigator view or to use it in JQL.
I think in your instances there is already a custom field which has been created by the admins called "Release date" and hence the confusion because you are thinking of this field as the one which should give you the date of the release of the fixVersion.
Please see this open ticket by using JQL with release date
https://jira.atlassian.com/browse/JRASERVER-22640
And the ticket for having release date in the issue navigator view in Jira has been set to "Wont do" by Atlassian.
https://jira.atlassian.com/browse/JRASERVER-10788
Jagriti
Hi Tarun
thanks for the quick response .
I have a gadget on the dashboard "Filter results gadget" which uses the JQL i have mentioned above,  on this gadget  i have myself added the field "release date"  as the management wants a view like that .
Is there any way the fix version can fetch its associated release date . May be a different jql etc.
Jagriti
or may a another gadget from the market place?
Nic Brough -Adaptavist-
May 6, 2019
Yes, adding a custom field to the issues, but not actually putting anything in it will give you an empty display.
I would throw that field away and replace it with a "scripted field" - Scriptrunner (I name this first because I work with the authors, and have used it for a lot longer than joining them, so I am most familiar with it) and other  scripting or automation apps can do this.
A scripted field can read the release date off the appropriate version and display it on the issue for reporting.  You will need to put some extra thought into it - an issue can have many fix versions, your code will need to read them all and decide which is most appropriate if it finds more than one.
Jagriti
I am new to this , how can i start off with scripted field. Please guide
May 6, 2019
You will need to install one of the scripting or automation apps first, then have a look at their getting started guides and code libraries.
Jagriti
which one is good to start with  under free and paid category ?
thanks alot !
May 6, 2019
The free ones I've seen have little interface points and no support, so I can't recommend them.
On paid, I would use scriptrunner for the reasons I mentioned already, but you might want to check out powerscripts, automation and autoblocks as the main ones that might help you most flexibly.
Like • 2 people like this
Tarun Sapra
I will suggest you Script runner,it has the most comprehensive feature set though slightly steeper learning curve.
