[Release Page] - Project -> Releases -> Select Version -> How to add one more field to this view?
Rajesh Krishna
Release Page View:
1. From the project, select 'Releases' - which will show all versions
2. Select any of the version
3. This page shows following fields for the issues - P, T, Key, Summary, Assignee and Status
4. How I can add one more field in this view - say 'Due Date'?
Jobin Kuruvilla [Adaptavist]
May 8, 2017
That page is not customizable. You cannot add new columns without the help of add-ons.
You can click on the "View in issue navigator" link to see the same issues in the issue navigator. You can add as many columns as you want in the issue navigator, when you are using the column view.
Rajesh Krishna
Thank you, Jobin. It will be really good if we can see due date also.
Learn more
