×I am thinking about creating a release workflow for some of my projects. I would like to create a "Release" issue, and have a transition called "Release", which would close the JIRA release version (mark the version as "Released") associated with that issue (the "Fix Version" of that issue). Currently I manually administer the project, click the cog icon next to the release version, then mark it as released.
Can this be done?
You will have to develop a post function that does this. Use VersionManager.
No idea what you mean at all. I am not finding the documentation clear at all. So what exactly am I mean to do with a post function and I have no idea how to use VersionManager. Perhaps you could give me step by step guide as I am new to Jira. The only reason I am using Jira is for defect management from TestRail.
Sian
This post is nearly 5 years old, and things have moved on a bit. As an old question, only a limited number of people will have seen your reply too.
I suggest you re-ask the question of the whole community, detailing your scenario, mentioning that you're using TestRail explicitly (as this question is not about TestRail at all).
If anyone looking for an answer to @Siddharth Srinivasan's question,
def project = ComponentAccessor.getProjectManager().getProjectByCurrentKey("PROJECT KEY")
def versionManager = ComponentAccessor.getVersionManager()
def version = versionManager.getVersion(project.getId(), issue.getFixVersions())
versionManager.releaseVersion(version, true)
