We have 5.1.3...
Besides using Jira for all our internal work (adminstration and software development), we're using it to manage customer interaction for our services.
Having the Agile link on the Dashboard has been nothing but a headache, as customer naturally follow it which just brings them to what's effectively an ad for Grasshopper, and is completely irrelevant. That would be bad enough, but then they start clicking on the links within that and become hopelessly lost.
I can't find any permission - project or global - that allows this to be hidden. And, of course, we don't want to disable it for our internal folks, so a global approach would not be ideal.
Is there some approach I can pursue?
Thanks, I'll go looking... Was it a paticular plugin you used to remove other links (I'd be interested in removing those as well)? We do have GH installed (for developers) and can separate the instances, but the users for this project don't have access for it, which I believe is why it goes to GH info web page...
