My team works with a workflow and I would like to remove irrelevant buttons from the Issue View screen to avoid confusion. I would like to remove the Assign button and some of the options under the 'More' button: Voters, Add Vote, Log Work.
I cannot apply it to ALL projects, only to some of them. Is there any way to do that?
I saw some solutions by Atlassian but they were all relevant to disable to ALL projects and it's not what I'm looking for.
@Meital You should create a custom permission scheme and associate it to this project then remove Assign Issues permission by removing the grant to (what ever is set there)
Hi, thank you for your answer. I still want users to be able and assign the issue (by using the workflow for example). But I want to hide the button itself. If I'll remove the permission wouldn't it restrict the user to reassign the issue from the workflow?
@Meital Yes it will, there is no other way to have the button removed and still be able to allow users to assign ticket in the View screen for a specific project.
But you could limit the group/role of who can by modifying the permission scheme for a particular project (best chance)
Help us plant more trees
