Remove Crowd from Jira and use only active directory
Sid
February 21, 2018
Currently we are using crowd for JIRA and Confluence. In future we would like to use only Active directory (groups to be created). What are the steps I need to follow inorder to make sure no user have trouble logging in?
Laurens Coppens
Are you using the crowd internal directory, or is crowd using AD for population?
Sid
February 22, 2018
we are using AD for authentication ; crowd we create all groups
Laurens Coppens
Then you have 2 options, create the groups in AD or in confluence/jira (i would prefer AD).
Then you have to link AD to confluence and jira, to make sure you see the users and groups from AD.
Then you just need to switch the order so that AD gets higher priority in the directory list.
I suggest to test this in either a demo/test environment or during a fixed downtime window.
You can't be sure there won't be any logon problems at all, but as the usernames are the same, there shouldn't be any login problems as long as your groups have the right permissions in the tool.
Sid
February 23, 2018
Thanks Laurens, i thought the same
Register now
