Remove Remaining estimate but leave Original estimate field on Create Issue screen
Oleksandr Presich
Please advise if it possible to show only one of these fields (Original estimate) on Create Issue screen.
They both appears after enabling Time Tracking field for the issue,,,but really there is absolutely no sense in manually duplicating value from original to estimate.
Oleksandr Presich
Guys, any ideas?
Stephan Hannach January 24, 2019
Turn on Legacy Mode via
Cog -> Issues -> Time tracking -> Legacy Mode -> ON
The Remaining Estimate Time should not show up any longer.
Daniel Everland
I don't see this option any longer. Any workaround?
Stephan Hannach February 26, 2019
Unfortunately it is not avaible in JIRA Cloud.
It is still available in JIRA Server at least till version 7.13.1.
carlos lugo
can scriptunner hide the unused fields?
Dhara Mistry-Kansagra March 20, 2017
Found a possible workaround on the following page: https://answers.atlassian.com/questions/11439406
Mayorov Alexander October 24, 2014
Hi, Oleksandr! Did you find any workaround for this case? Need the same...
Oleksandr Presich
Atlassian is spamming me about unresolved question, so I will be spamming here))
Any ideas how to get such functionality, guys?
Andris Grinbergs
April 21, 2014
Please check if you don't have CUSTOM field in your jira by any of those 2 names. If you have try to remove it from your create issue screen or from Jira. This should solve it.
Oleksandr Presich
I don't have it. That is standad JIRA behaviour - if you add Time Tracking field, you really get both Original and Estimate. That's do not impact seriously but a bit annoying)
dnichols4 August 23, 2014
Did you ever figure this out? I experiencing a similar issue - both estimate fields showing up on a transition screen & would like to only have original show.
Oleksandr Presich
Nope) Seems nobody needs it except us)
Andris Grinbergs
February 20, 2015
You can enable time tracking legacy mode.
