Remove "Filter Results:" text from gadget title on dashboard
Tiffany Owen
May 9, 2017
I want to remove the "Filter Results:" text from the title of my filter results gadget on my dashboard. I believe I might have to edit the XML file and give it a blank title... could someone tell me where to find this file or what it is called? Thanks.
Jobin Kuruvilla [Adaptavist]
May 9, 2017
It is slightly easier in this case because the gadget gets that text from the i18n property files. You can modify the gadget.filter.results.specific.title property in JiraWebActionSupport.properties file under atlassian-jira/WEB-INF/classes/com/atlassian/jira/web/action folder. You will need a restart.
Having said that, I will pass it if I can because you will have to keep doing this for every upgrade. A better option might be to rebuild the filter-result gadget, as a new plugin, and modify the title in gadget xml. You just need to start using the gadget from the new plugin.
Tiffany Owen
May 9, 2017
Thank you! I edited the gadget.filter.results.specific.title in JiraWebActionSupport.properties by taking out the "Filter Results:" part of the title and then saved it and then restarted my JIRA service. However, it still looks the same on the dashboard. Is there something else I am missing to make it accept the change? Thanks for the help!
May 9, 2017
What is the language configured in your JIRA instance?
Tiffany Owen
May 10, 2017
Java, I'm assuming?
May 10, 2017
Sorry, I should have been clear. I am asking about the user langauge. Is it English (US) or English (UK)? If you are using a different langauge, and not the default one, your property file will be inside the i18n jar file.
Tiffany Owen
May 11, 2017
English (US.) It is working now, Thank you so so much!
Madhavi Kurapati
February 10, 2020
I also have the same question , But I am not able to find the 'gadget.filter.results.specific.title' to edit.can you please help me to find that file?thank you..
Nayereh Keramatnezhad April 7, 2020
check your file with this name JiraWebActionSupport.properties in this path:
Monika Antos October 20, 2017
New feature was released in July, where dashboard gadgets can now be renamed in JIRA. Just hover on the gadget's title bar and select the more (…) button. Then, choose Rename.
Tiffany Owen
February 28, 2018
Is this for the Cloud version only? I am using a Server version and don't see that option
Eilyn Peña
August 24, 2018
Same issue as Tiffany!
I cannot see the "Rename" option in Server version
Regards
Eilyn
Colinda Goormans-Francke March 25, 2019
Here the same problem. Would love to be able to rename it.
The solution to modify the JiraWebActionSupport.properties seems complicated to me. A simpe rename would be great!
Nic Brough -Adaptavist-
May 9, 2017
You'll need to find the atlassian-plugin.xml file in the source code, I think the file you will need to open up is jira-gadgets-plugin.<some number>.jar as that will contain that file.
