Remove/replace native jira menu link
Jakub Papcun
is it possible to remove a menu item from the menu (for example menu for More Actions in any issue - let's say I want to remove link to Clone operation) that belongs to jira itself and not to my plugin. Or replace/override the menu item that already is there with my own web-item?
Thanks for any help
Jobin Kuruvilla [Adaptavist]
March 21, 2012
The menu items are implemented in JIRA as plugins. For example, issue operations can be disabled by going to Administration > Plugins> System Plugins and disabling the appropriate moduel in Issue Operations Plugin.
Remember, the change will be global. i.e. across projects.
Jakub Papcun
Great thank you that helped a lot. Is there a way to "override" this link and display my own i.e. dialog instead of JIRA dialog when clicking on JIRA menu item?
Ricardo Solar
November 14, 2013
I've tried to follow your instructions in order to disable the issue native menu but couldn't find the plugins in the described path...
I'am using JIRA v6.1.1 and service desk addon, is this still possible to do on this version?
Thanks for your help
Kubo Grznarik
The plugin is called Atlassian JIRA - Plugins - Header Plugin and in this plugin you should disable "Help Menu Panel"
