Removing Development panel from Issue screen
Swati_Mathapati June 13, 2023
Is it possible to remove development panel from Issue page for a specific project ?
Aron Gombas _Midori_
Remove the "View development tools" permission from everyone in that project:
https://confluence.atlassian.com/jirakb/how-to-remove-or-edit-access-to-development-panel-701268686.html
Yes ,that worked for me but we do have Slack, Jigit development tools ,do you have any idea how to remove these tools ?
Your options:
  1. Can those be controlled with similar permissions? If yes, then it would be the right way.
  2. Can you remove those by configuring the corresponding screens? If yes, then create a screen with these removed and use that screen in those screen where you don't these interfaces.
Swati_Mathapati June 20, 2023
We have checked with script as well , it isn't possible to remove other tools
@Aron Gombas _Midori_ Thank you for your response
Move Work Forward
You also can disable a module for a plugin, in this case Jigit, do remove the functionality.
However, there is an easier way - there is a setting for global admin to hide the development panel.
Leo
Casper
To remove any panels or fields from the issue screen you should go to:
Project Settings > Issues > Layout > Choose the issue type you want to edit.
I hope it will help you)
@Casper Thank you for your response
Like • Casper likes this
