I use CCC last comment plugin, is there any way that i can replace this plugin with scripted field from script runner.
From memory, a scripted field that does something like
def allComments = CommentManager.getComment(issue)
gets you a list of all the comments. What I can't remember is how it is sorted, but if it is by Id of the comments, then just grabbing the last element from it (as lastcomment) should get the comment, then you can say
return lastcomment.getBody()
To put the text into a scripted field. You might also want to add lastComment.getAuthroFullName() and lastComment.getCreated(). (And have a think about looking at the last user to amend it instead of original author)
Can you please attach link or which can explain me briefly.
SAI
You should create a new custom field of type "scripted field", then go into Admin -> Scriptrunner -> scripted fields, and add a script to it.
That script should
Thanks Nic Brough, i tried your steps and i successfully get the latest comment using script runner.
