Replicate “Release Burndown” in Eazy BI
siva
Is there any possibility that we can replicate the Release burndown in Eazy Bi,
we are having a request to Build a release Burndown report in Eazi Bi from the imported data.
any chance i can import a definition to a dashboard.
Jack Nolddor _Sweet Bananas_
Hi siva,
You are correct, currently, it is not possilbe to import issue release change history and, thereby, to create release burndown chart, due to technical limitations.
Here you can find some reports samples you can check about versions.
You can also create your own one, by copying the report definition of any report
See Export and import report definitions for further information about how to do it.
Then, you can also publish on a Jira dashboard or a confluence page, check Publish Reports section.
Let us know if the given advice solves your problem or if you need further support with this topic,
Kind regards
siva
Hi Jack,
Thanks for the response ,
Im trying different metrics with the dashboards,
Do you have any report definition that is closest to the Release Burndown .?
Probably the Version Report
Regards
Like siva likes this
