Report on issues Resolved By
GilK
April 30, 2012
I'd like to display a chart (or a list) of all my users and how many bugs they had resolved in the past 30 days.
How do I do it?
Janiv.
Cyril Egan
April 30, 2012
The Jira Enhancer plugin will probably give you what you need.
https://plugins.atlassian.com/5139
Create 2 custom fields
  • One of type Last Resolution User
  • One of type Last Resolution Date
Create a filter "resolutiondate <= 30d".
Use the "Two Dimensional Filter" or "Issue Statistics" gadget on a dashboard and put the "Last Resolution User" a one of the parameters into the gadget config. Choose the filter to limit the list of issues.
Note:
This of course won't cover the use case of an issue being resolved multiple times in the last 30 days by different users. It'll just show the last user to resolve.
GilK
April 30, 2012
Will it work retrospectively?
Cyril Egan
April 30, 2012
I believe so. I just use the 'Last Resolution Date' one and it appears on all my issues even those created/resolved before the plugin was deployed.
GilK
April 30, 2012
Hi, When I use it, all my issues get the value 'none' for the Resolved By. Thanks, J.
Cyril Egan
April 30, 2012
Just a guess but if possible try a re-index. I'd try it on a test instance if you have it available first.
GilK
May 1, 2012
Worked!
Cyril Egan
May 1, 2012
You're welcome - glad it worked!!
Register now
