Report to show fix version changes on issue
Krishnanand Nayak
June 8, 2018
We are trying to create a eazybi report that will show the fix version changes on a issue.
for example:
1) Issue A was part of the current release, but was moved to a different release
2) Issue B was in future release but was changed to the current release
The report should be able to show all these changes.
Jack Brickey
I don't use easyBI but you can create a JQL using fixversion, e.g
fixVersion was 1.3 and fixVersion != 1.3
Krishnanand Nayak
June 11, 2018
Thanks Jack.
the report we are looking to create should show the management the change of fix version on a issue.
Rajni_Singla June 21, 2019
@Jack Brickey How about if I need a report which has test step including right now I am able to comments in the report
Jack Brickey
@Rajni_Singla , i do not understand your question. It does not seem to apply to the original post at all. Maybe a new question/post is warranted?
Deekshith Musthyala
June 29, 2020 edited
Use JQL changed keyword as " fix version changed " before-after etc.
Shagun Sharma
January 24, 2022
fixVersion changed FROM "1" TO "2" does not give any results even when there are tickets that got moved from fix version 1 to 2.
Any help on this?
Ilze Leite-Apine - eazyBI
currently, eazyBI does not import changes for multivalue fields (versions, labels, components etc) due to technical limitations, therefore, it is not possible to create a report on issue release changes.
We have this improvement in our backlog. I will post here when something new appears.
Ilze, support@eazybi.com
Krishnanand Nayak
June 20, 2018
thanks for the response. Can you provide the improvement link here so the users who need this feature can watch it?
eazyBI backlog is for internal use. All the features are included in the changelog when a new version is released. You may want to follow eazyBI in the marketplace to get informed when a new eazyBI version is released.
Best,
Ilze
Deleted user October 21, 2022
@Ilze Leite-Apine - eazyBI has this improvement been implemented yet?
Learn more
