Hi
I have return the script to copy reporter field from parent to subtask but it is not working. Here is my script. Please verify.
import java.sql.Timestamp
import com.atlassian.jira.event.issue.IssueEvent
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
def issueManager = ComponentAccessor.getIssueManager()
def changeHolder = new DefaultIssueChangeHolder()
Issue issue = event.issue
def cwdUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def currentReporter = issue.getReporter()
log.info("Reporter+++") //for checking
def change = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "reporter"}
log.info("reporter++++++++++++") //for checking in execution
if (change) {
issue.getSubTaskObjects()?.findAll { it.issueType.name in ["Sub-task"]
def subtask = ComponentAccessor.getIssueManager().getIssueByCurrentKey(it.key)
subtask.setReporter(currentReporter)
log.info("currentReporter")
ComponentAccessor.getIssueManager().updateIssue(issue.reporter, subtask, EventDispatchOption.DO_NOT_DISPATCH, false)
Vamshi
Hi Vamshi,
I tested your script and I can confirm that it works. My assumption is that you're implementing it as a Custom Listener.
For the Events in the listener, I chose Issue Updated.
To test the listener, simply change the Reporter in an issue and check the Reporter value on its subtask(s). It should be updated to match that in the parent issue as well.
I hope this helps.
