Reports per cuustomer in Jira
Jo
I have a section for Projects in Jira. Is there some way through which I can create report of how many projects each customer has ?
Anna Cardino
May 28, 2014
Dear Loana,
By default, these are the ones that included in JIRA https://confluence.atlassian.com/display/ATLAS/Reporting+in+JIRA
If your requirement doesn't fit any of these, you might need to use third party plugin to generate the report.
I am not sure what do you mean by customer? Are you referring to the Project Lead?
Monique
