We have recently upgraded to Jira v9.4.5. After upgrading my users have noticed that our single select custom fields are not defaulting to NULL. It is defaulting to the first option in the dropdown list.
Example, I have a custom field called Benefit Type that is set as a required field. The first option in this field is "Anesthesia". Prior to the upgrade the field would default to NULL and the user would have to select an option from the dropdown list before creating an issue. Now the field defaults to "Anesthesia" and if the user doesn't change it, the issue will be created with this option selected.
Also, Benefit Type is a Dynamic Select Field using the Dynamic Forms for Jira app. Get started - Dynamic Forms for Jira (deviniti.com)
Has anyone else seen this issue?
Here is a print screen of the field and the new defaulted value. It used to say "None"
Should look like this...
