Issue type field doesnt populate the issue types listed in edit screen which is created and attached to edit screen. Where as the create issue screen has issue type field and has all 4 fields populated . Copied the same create issue screen for edit issue screen
Hello Gunaa,
I am not sure if I have properly understood your question... Could you please elaborate a little bit more?
Could you please provide us with some screenshots better explaining your scenario?
It seems that you are having some trouble to find some issue types under the issue type drop-down field on your issues when editing it, is that correct?
If that's the case, please check if the Issue types are properly added in the same workflow as the current issue type of the issue on Project settings > Workflows. If it is not, you will only be able to select a different issue time using the Move option in the three dots (...) drop-down.
We will be waiting for your answer.
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
