Required fields
paul.devereux@irislegal.co.uk January 30, 2013
I have a need for a field to be Mandatory when an issue is moved from 1 issue type to another however the field should not be mandatory if a new issue is created directly.
For example:
I require a "Considered Response" field to be mandatory when moving a T3 Incident issue type to be a Defect issue type.
I do not require this information, and it would not be known, if a user is creating a Defect issue type directly in the project.
Is this possible, and if so how would I best achieve this?
Many thanks in advance
Nic Brough -Adaptavist-
January 30, 2013
Field configurations are flat. If a field is mandatory for an issue, it is mandatory. So you can't do it.
What you could do is have different workflows for each issue type, and place "field is mandatory on transition" validators on them. This would not stop someone moving an Incident to a Defect, but they would not be able to transition through any workflow until the field was filled in (obviously, you don't validate the field on "create defect")
Naren
January 30, 2013
Since you want the customfield only to be mandatory on certain transition, you can try using the Jira Suite Utilities and add the Fields Required Workflow Validator on the transition where you are moving the T3 Incident Issue Type to the defect Issue Type.
Hope this helps!
atlassian, confluence, loom, atlassian intelligence, ai notes, ai-powered meeting notes, atlassian community events, ace, confluence ai, loom ai integration, ai note-taking, atlassian ai features, team '25, atlassian live learning, confluence automation
Unlock AI-powered meeting notes: Join our live learning session! 📹
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!
