Requiring Values for Field
Christopher Cannata February 19, 2014
Hello, I am trying to force users to fill in values for a custom field if the value of a different field is set to a certain value.
Example: I have a custom field "Linked Issues". I want users to have to provide a value for this field if they specify the value "Duplicate" in the Resolutions field.
Sameera Shaakunthala [inactive]
February 19, 2014
I guess you want to perform this validation when performing a certain workflow transition. You can write a Groovy script validator for this. You need to install Groovy runner plugin for this.
Using Groovy, you can check the values of Resolution and custom field, and then display an error message and prevent status transition.
Alternatively, you can use use Behaviours and Groovy runner plugins together. Behaviours may work in issue edit screen as well. I guess following code will work for Behaviours.
if(!getFieldById("customfield_10000").getValue() && getResolutionObject().getName() == "Duplicate"){
  getFieldById("customfield_10000").setError("Resolution is Duplicate. You must set a value for this field.");
 } else {
         getFieldById("customfield_10000").clearError();
February 19, 2014
By that you mean the list of issue links?
So, as per my understanding, if the Resolution is Duplicate, then at least one issue link (probably the duplicated issue) must exist. Am I right?
I made a mistake, Linked Issues is not a custom field, it is a field provided standard with Jira. I can't get it to work, because I am not sure how to specify it to throw the error if Linked Issues is left blank.
That is correct. I am trying to force our users to provide at least one issue link.
February 19, 2014
You have to have Groovy runner plugin for this.
For the workflow status transition where you need to perform the validation, add a 'script validator' - 'Simple Scripted Validator'. Part of what you need is already there - a bultin line of code. (Has at least one outward duplicate link)
issueLinkManager.getOutwardLinks(issue.getId())*.issueLinkType.name.contains('Duplicate')
If you can change it to something like this, it should work.
issueLinkManager.getOutwardLinks(issue.getId())*.issueLinkType.name.contains('Duplicate') || issue.getResolutionObject().getName() != 'Duplicate'
mdistester2 mdistester2
April 4, 2019
I'm new to all these but I'm tasked to do something similar to this.
From what I understand I need something called script runner( which my company has installed)
I start by going to the workflow that I want to run this on, and add the code above? to the script runner for it to work.
I don't know much about coding and as such I have no clue why I'm getting error while copying said codes above.
Both the long one for behaviour or the short one for the scrip runner
Register now
