An issue is declared as 'duplicates' using Link function.
Immediately after it, the Resolution should be set as 'Duplicate'.
User should not do it manually...
Some idea how to implement it? (I know there is no Link Event)
Thanks.
Hi, Gaby.
There is this improvement request to link when setting the resolution as duplicate (the other way around) : https://jira.atlassian.com/browse/JRA-3758. It links you to this documentation: https://confluence.atlassian.com/display/JIRA/JIRA+4.4+Release+Notes#JIRA4.4ReleaseNotes-IssueLinkingwhenResolvinganIssue.
Also, there is one improvement request for that: https://jira.atlassian.com/browse/JRA-21265, but it is set as duplicated to the previous one I sent. I don't think those are exaclty the same thing, but that was what they thought.
I hope it was helpful.
