Resource Management Report -- Over all projects
Tiash Zaman
November 18, 2014
Hello:
I like to know in ALL the projects (company wide), not in a single project:
 How many Issues are currently assigned to a user,
how many have they completed in a given period,
and how many estimated hours of work is assigned to them for a given period .
Asael Sepúlveda
You have to create filters for each one:
 How many Issues are currently assigned to a user: Create a filter that shows every issue and use it on a pie chart gadget grouped by assignee. You can also just query for assignee = <User> to see the results size
 how many have they completed in a given period:
  1. resolutiondate < now()
  2. resolutiondate < "2014/11/01" and resolutiondate > "2014/10/01"
how many estimated hours of work is assigned to them for a given period: you can use the workload gadget
Asael Sepúlveda
Hey Tiash,
 As for saving the reports, you can save them as filters and from there you and your users can subscribe to them in order to receive them periodically:
https://confluence.atlassian.com/display/JIRA/Receiving+Search+Results+via+Email
 As for the workload pie chart, you do need the JIRA charting plugin and also have time tracking enabled:
https://confluence.atlassian.com/display/JIRA/Workload+Pie+Chart+Report
Midori
March 24, 2015
You can create this report and any custom multi-dimensional report like this:
  1. Create a JQL filter that returns the issues (from all the projects) that you want to include in the report. At this point you probably want to filter these to the "given period" you mentioned.
  2. With the Better Excel Plugin, create a template which exports the following raw data for each issue:
Column "A": issue key
Column "B": assignee user name (or display name)
Column "C": resolution date (if resolved) or leave it blank
Column "D": estimated hours
  1.  Finally create the following Excel pivot tables:
Between column "A" and "B": how many Issues are currently assigned to a user
Between column "B" and "C": how many have they completed in a given period,
Between column "B" and "D": how many estimated hours of work is assigned to them for a given period
This should be fairly straightforward if you follow this Excel pivot table tutorial.
Tiash Zaman
November 19, 2014
Thanks Asael for your response.
For the Workload Gadget â€“ I used the  Report: Workload Pie Chart Report and got this 500 error: java.lang.NoSuchMethodError. Do I need to download and install the JIRA Charting Plugin?
Also, how can I save the reports in JIRA?
Help us plant more trees
