Restrict Customfield by only one Group
How many ways can we do
Hi @Tharunkumar B ,
There is no direct way in built in Jira. Alternate you can achieve it with workflow. Below are the steps, please try and accept the solution if it works for you.
Step1: Create a screen with custom field you want to restrict.
Step2: Edit the exiting workflow and add transition at every status which points to same status itself i.e self transition with some step name.
Step3: Place the screen on above transition.
Step4: Add condition 'User Is In Group' on above transition which allows only specific group of users.
Regards
RK
