×Hello
I am importing a single project in JIRA , JIRA shows as *ProjectImport* under *IssueHistory* & *Actvity* Tab of each issue in that project.
I don't need JIRA to show this history. PFA
Please let me know the possible workaround.
You can delete the entries from changegroup and change item tables
you will have to run two queries , first to delete entries from changegroup then from changeitem
this is the first query
delete from changegroup where id IN (select ci.ID from changeitem ci,changegroup cg where field='ProjectImport' and cg.ID=ci.groupid);
this is the second query
delete from changeitem where field='ProjectImport';
this should delete all the entries from both the table and nothing about project import will be displayed in history
NOTE:first query should be executed first and then the second one
If you're going to edit the issue history with SQL, then you absolutely MUST
Never never never run SQL updates against a running Jira, you can easily destroy it. (There are minor exceptions, and the damage isn't always catastrophic, but the advice remains "don't")
Thanks Nic & Mizan .
It worked for me .
On most events, you can place view restrictions (like on comments). What you can try is to restrict the viewing of this import event to admins only. That way normal users should not see this event. Not sure how you can do that though.
