Restrict Resolution field's options in Edit screen
Kris Han
Hi everyone,
As title, How should I restrict Resolution's option in Edit Screen? I know how to use jira.field.resolutions.include but this is only for workflow transition not for Edit screen. Please help me on it. Thank you very much!
Best Regards,
kris
Joe Pitt
You should NEVER put the resolution field on an edit or create screen. Whenever it is presented it is REQUIRED. It should ONLY be put on the screen shown during the transition for setting it.
If you put it on the edit screen it will be required the first time someone edits the issue.
