Restrict creating of certain issue types with behaviour
Rob B
March 26, 2024
Is there a behaviour to stop certain users from creating old issue types?
We dont use some issue types now, but cannot delete them due to existing issues. Is there a way to allow onto one user group to create the old issue types?
Sean Chua _Adaptavist_
March 31, 2024
Hey @Rob B ,
Saw that you are trying to limit issue type based on user group. You can check this community post for a sample on how you can achieve that.
Essentially, use " groupManager " and specify groups:
In this scenario, you will need to use the Behaviour Initialiser instead of the Server-Side Behaviour.
And the groups that are going to be tested is the jira-administrators group and the Developers group.
To invoke the groups you want to use, you will need to use the groupManager and specify the group names you want to use
Hope this helps.
Sean
Asha Goyal
March 26, 2024
@Rob B
Kindly refer below link for restricting issue type with behaviour in Jira.
https://docs.adaptavist.com/sr4js/8.18.0/features/behaviours/behaviours-examples/restricting-issue-types
Please Vote and Accept my answer if it helps.
Rob B
March 26, 2024 edited
Does this use with User Groups that i have created?
SERVER
VERSION
7.13.1
