Restrict issue to move to Scrum column without a "fix versions" data field
Caprieact
May 22, 2023
Hi all,
is there a setting to prevent issues who not have a "fix versions" data field to move to the next scrum column?
Trudy Claspill
Hello @Caprieact
You can do that by setting up a Validator on the Workflow Transition that is executed when the issue changes to the specified status in that column.
If you are working in Jira Server or Jira Data Center, that is something that can be done by a Jira Administrator.
If you are working in Jira Cloud with a Company Managed project, that again is something that can be done by a Jira Administrator.
If you are working in Jira Cloud with a Team Managed project, you would set a Workflow Transition Rule, and that could be done by the Project Administrator for that project.
