I want to restrict sub-task types if i try to create a sub-task for an issue
@Renjith
Hey Renjith, I am not getting the exact solution so modified the question as new one.
@Mizan
Based on the Issue type(i.e for Bug some sub-task types only)
On what conditions you want to restrict them ?
There are three questions you have created for the same problem. Please avoid doing it.
