I am trying to add a BEHAVIOR to set description with default values which i can edit before i create the ticket. And i am using the following script for it. Which work fine in bits and pieces, the not working parts comes in when i edit the ticket it erases the fields edited values and fills the default values.
so i tried a workaround by adding to the field and setting a condition to the workflow action.
Please need your help guys.
Script:-
import groovy.transform.Field
def StoryDefaultDescValue = """Default values for story"""
def DefectDefaultDescValue =""" Default values for defect"""
def projectKey = getIssueContext().getProjectObject().getKey()
def issueTypeName = getIssueContext().getIssueType().getName()
if(getAction()?.id != 1 || issueTypeName == "Story"){
getFieldById("description").setFormValue(StoryDefaultDescValue)}
if(getAction()?.id != 1 || issueTypeName == "Defect"){
getFieldById("description").setFormValue(DefectDefaultDescValue)}
HI. Check Screen
if(getFieldScreen().name == "Project CREATE Ticket Screen"{
if(issueTypeName == "Story"){
if( issueTypeName == "Defect"){
