Retrieve a radio button value
Christophe Leite
I've got a field named "Asked" with 2 possible answers (Yes or No) in my issue.
In my workflow, I would like to retrieve the field value.
How can I do that ? I've tried
cfValues['Asked'].getValue() == 'Yes' but that doesn't work... :-(
Christophe
RambanamP
August 20, 2013
the following code i have usedto get radio button value
CustomFieldManager cfm = ComponentManager.getCustomFieldManager()
CustomField asked = cfm.getCustomFieldObjectByName("Asked")
Option option=(Option)issue.getCustomFieldValue(asked);
if (option.getValue().equals("Yes")) {
// remaining code here
if you are doing it by Behaviour plugin then try with this code
FormField asked = getFieldByName ("Asked")
String value = asked.getValue()
if (value == "Yes") {
check this document to get some sample codes
https://jamieechlin.atlassian.net/wiki/display/JBHV/Miscellaneous+Behaviours+Examples
Christophe Leite
So, in my case, should it be cfValues['Asked'].option.getValue().equals("Yes") ?
RambanamP
August 21, 2013
something like this
cfValues['Asked'].getValue().equals("Yes")
can you check what value it will return the following code
RambanamP
August 21, 2013
i have update my answer try with that code it should work!!
Christophe Leite
How can I display tis value in a message box ?
Learn more
