Reusable Script Runner code
Erik Saline July 19, 2018
I am creating a few Script Runner built in scripts, rest end point scripts and custom fields scripts.  These scripts have code that can be reused, I am looking for the best way to share this code between the scripts.  Currently I am creating the code in Java and uploading the JAR file to the JIRA class path.  This works but requires a JIRA restart each time the reusable code is updated and re-upload of the JAR file.
Any ideas would be appreciated!
2 accepted
Mark Markov
July 19, 2018
Hello @Erik Saline
I am also recommend read this articles
https://community.atlassian.com/t5/Jira-articles/Work-with-your-Jira-plugin-from-Adaptivist-ScriptRunner-or-how/ba-p/719050
https://community.atlassian.com/t5/Jira-articles/Part-1-How-to-deploy-Adaptivist-ScriptRunner-scripts-and-objects/ba-p/794887
First one about how to create helpers classes to avoid code duplication.
And second one step-by-step guide how to create scriptrunner-plugin.
Hope it helps!
Great, thanks for the reply, I will check it out!
Kristian Walker (Adaptavist)
Hi Erik,
Have you looked at creating a ScriptRunner script plugin as described here in order to see if this will meet your requirements.
Kristian
