Hi Community,
we need to have "Review field mandatory during transition, from one status to another. kindly suggest using post function.
M
Hi @Manoj ,
You can make use of field required validator in your workflow. Until all required fields are not filled, it will not allow user to change the status.
i.e. Open the workflow --> Edit and click on required transition.
Add validator --> Field Required Validator
In the next screen, select the fields required and publish the workflow.
@Rilwan Ahmed Hi, i exactly did the same thing as i was aware of this, but unfortunately its not working.. pls see below...can your suggest ?
Remove the Conditional Validation and check.
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
