We recently did an upgrade to JIRA 4.4 from JIRA 3.x. One feature that I used often was to browse the commits associated with a particular JIRA and see which change sets were not reviewed. If a chance set had a review, it would have a little crucible icon beside it with a link to the review. This feature seems to be missing from the new JIRA 4.4.
I upgraded the Application Links to Fisheye/Crucible to ensure it had proper 2 way communication. This enabled a "Review" tab, but as you can see below, looking at the "Source" tab, I'm getting a suggestion to create a Crucible review for change sets that have already been reviewed.
But at least one of them has been reviewed.
Hi Arthur,
This has been fixed in version 3.2.2 of the JIRA FishEye plugin. This version is compatible with JIRA 4.4. You should be able to upgrade the plugin directly from the plugin manager in JIRA or head over to our plugins exchange: https://plugins.atlassian.com/plugin/details/290?versionId=406680
https://studio.plugins.atlassian.com/browse/FISH-465
Seb
I got access for the Universal Plugin Manager with firewall rule changes, but I don't have the ability to upgrade the fisheye plugin, mine is left at 3.2.1. Should I just download it from the website and upload it?
I downloaded the 3.2.2 version and installed it manually. I can confirm the issue is fixed. Thank you.
