Road Map in JIRA for Multiple Projects?
Radim SM December 10, 2018
Can I create single Road Map for Multiple Projects?
Scott Theus
December 10, 2018
Not out of the box, you need an add-on like Portfolio or Big Picture to create program-level road maps. Next-Gen project road maps are only at the project level.
-Scott
Thanks.
Radosław (SoftwarePlant)
Hi Radimfrancesco,
It is easily possible using our BigPicture plugin. Just create a Program and put both Projects in it's scope(you can use Projects Filters or Boards in any combination) then just use the Roadmap or Board module depending which you prefer.
Feel free to ask any questions about configuring and functionality of the plugin through our customer portal.
SoftwarePlant Team
