Dears,
I have Jira installed on Centos 7 .
and Active Directory Windows 2016.
I need to activate over SSL connection between them,
After, I created the CA Certificate and Import in into Jira. and trying to connect through SSL
I go the below Massage :
Connection test failed. Response from the server:
AD:636; nested exception is javax.naming.CommunicationException: AD:636 [Root exception is javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: No subject alternative names matching IP address AD IP found]
Karrar,
I believe this knowledge base article will help you resolve your issues. https://confluence.atlassian.com/jirakb/java-security-cert-certificateexception-no-subject-alternative-dns-name-matching-hostname-found-297669411.html
